pity, you missed a nice drive. other than a massive pot hole on the way in. which i managed to miss some how. :ph34r:
could have co piloted for ralf? i was going to offer but had a last min co driver of my own.
thanks joe for the run around the hill on the way in, twas a nice piece of road.
and thanks for the intercooler and bits. now all i need is time....and will power.
I will b making more of an effort soon hehe.
Hit me up if u ever want a pair of hands for the job dude, ive had my cooker fir a few days now. Prolly wont b in for a few weeks due to the time needed ti commit :P
Hey, anyone going to that BBQ on Sunday?, thinking about it but have my boy with me so don't want to have him all cooped up in a car all day with no playing, so just think if there is going to be a few people there with kids as well, then I'll probably go as well.
Oh and Bodo, no worries mate, found that nice piece of beginners twisties a few years back, I could do an avage speed of 55 through that in the poosar
mate, i am so jelous, been trying to talk mel into letting me get a home stereo (plus a nice big t.v.), but i think i did alright this weekend, managed to get the complete star wars saga on blu ray tongue.gif
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
