You need a car that runs first troy :P
thursdays might be a better day for some now, i will attend every day for 2 weeks, then i need to skip b/c of work.. what kind of meet, the usual?
is anybody elses channel 7 and some of channel 10 gone bad since all the rain??
mine keeps dropping out or just goin real bad for a while then comes good and repeat..
thinking maybe some water got into teh cabling but only affecting channel 7 and somtimes channel 10 makes it wierd??
my antenna is not even 1 year old so it can't be that
well mate, as my job description is broadcast technician, and i work in the field, the problem you seem to be getting has nothing to do with your end, it is actually the broadcast tower itself, now without seeing in person both your end and the broadcast site, i couldn't be much more help, the best answer i could give you would be to wait till tomorrow and see how things go, and to be honest, it is a little late at night
sorry i couldn't be of more help
Yeah the other TVs work perfect(gets the missus off the loungeroom tv so I can watch movies or play Playstation lol. But that's not the point...
So you think it might be the cable to the socket??
Quite possible man, plug the working tv into tht spot and if kt works the charm its the tv, if it doesnt theres something wrong with that line alone, also swap the antenna cords as well(try it all bar the hammer!$
So...
This Weds or Thursday coming seems like a good time to do a meet, the question is where?
Possibly Carsedline (a good drive would be fun) and the Morayfield'ish liners can meet at the usual spot on the highway @ the BPs?
For a minute there I thought i'd clicked on tellytroubles.com but no, its SAU :)
Well, we're more than able to attend the weekly meet n have a feed, but someone... (Ash?) may have to provide a back seat and door to door service... Its coming along, but very slowly. Other jobs keep jumping in front of it.
Found a 25DET +ecu + running gear for $1500....all I need now is an LSD and a free weekend...
and some cash.
*passes bowl around*
Crapstix. Worth a shot. :(
Start work tomorrow, so good to be employed again, nearly 3 months on the sidelines sucked ass. Hope to catch ya's on the weekly.
Ash! Msg me n let me know wats going on ;)
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
