No horsepowers intended.
i was going to get a full set of Superpro suspension and cradle bushes. But I just got back from Fulcrum (because I missed the tech night there) and other than a loose top bolt on the drivers side rear strut top, all my bushes are good.....they were quite surprised, and I can spend $580 elsewhere :)
So now that my plan has changed. I'm not sure what exactly to get, but this is my list so far.
Hicas locking bar
Center caps for wheels
Wrap or plastidip center console inside.
New video card and mousepad (already paid for and installed)
new front rotors and pads...finally get rid of that annoying and increasingly ear piercing squeak.
New front speakers.
Brake fluids replaced and new ABS module (if I can find one for a reasonable price)
Booze for origin tonight
Jim Richards dinner tomorrow night.
Get my exhaust lifted up higher under the car.
and If cash permits Either build a new computer (only need CPU, MoBo, RAM, and cooler) or swaybars.
Hicas locking bar
New front speakers.
None of this involves an ECU and tune...I think you have missed something.
Hicas locking bar
Bodo, if your considering a hicas lock bar. This might be worth a look... A full eliminator kit, i got this on my car and find is absolutely awesome. Car feels s much more connected to the road etc. But i have not driven a car with Lock Bar only so not sure of comparison. I was pushed towards this kit instead of the bar only
http://shop.cartel-aus.com/Total-HICAS-eliminator-kit-for-Nissan-dw015.htm?categoryId=-1
Sweet! bright orange, can you see it under the car at all?
this is the one I was going to get. As it saved having to replace the hicas tierod ends.
http://www.ebay.com.au/itm/Total-HICAS-Eliminator-Kit-for-Nissan-Silvia-S13-S14-S15-Skyline-R32-R33-R34-/181145112508?pt=AU_Car_Parts_Accessories&hash=item2a2d170fbc
But seeing as everything is fine under there, I'm just gonna stick with getting the regular old locking bar. as there is a big price difference.
Yes, orange is very visible under the car
:/ I'd avoid then unless cop attention is what one is chasing. Apparently new laws coming out and they might be trying to get us for lots more srupid little things.
