No horsepowers intended.
i was going to get a full set of Superpro suspension and cradle bushes. But I just got back from Fulcrum (because I missed the tech night there) and other than a loose top bolt on the drivers side rear strut top, all my bushes are good.....they were quite surprised, and I can spend $580 elsewhere :)
So now that my plan has changed. I'm not sure what exactly to get, but this is my list so far.
Hicas locking bar
Center caps for wheels
Wrap or plastidip center console inside.
New video card and mousepad (already paid for and installed)
new front rotors and pads...finally get rid of that annoying and increasingly ear piercing squeak.
New front speakers.
Brake fluids replaced and new ABS module (if I can find one for a reasonable price)
Booze for origin tonight
Jim Richards dinner tomorrow night.
Get my exhaust lifted up higher under the car.
and If cash permits Either build a new computer (only need CPU, MoBo, RAM, and cooler) or swaybars.
Hicas locking bar
New front speakers.
None of this involves an ECU and tune...I think you have missed something.
Hicas locking bar
Bodo, if your considering a hicas lock bar. This might be worth a look... A full eliminator kit, i got this on my car and find is absolutely awesome. Car feels s much more connected to the road etc. But i have not driven a car with Lock Bar only so not sure of comparison. I was pushed towards this kit instead of the bar only
http://shop.cartel-aus.com/Total-HICAS-eliminator-kit-for-Nissan-dw015.htm?categoryId=-1
Sweet! bright orange, can you see it under the car at all?
this is the one I was going to get. As it saved having to replace the hicas tierod ends.
http://www.ebay.com.au/itm/Total-HICAS-Eliminator-Kit-for-Nissan-Silvia-S13-S14-S15-Skyline-R32-R33-R34-/181145112508?pt=AU_Car_Parts_Accessories&hash=item2a2d170fbc
But seeing as everything is fine under there, I'm just gonna stick with getting the regular old locking bar. as there is a big price difference.
Yes, orange is very visible under the car
:/ I'd avoid then unless cop attention is what one is chasing. Apparently new laws coming out and they might be trying to get us for lots more srupid little things.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
