Afternoon all :)
Here's to Friday! :cheers:
Wow didnt realise there were so many here,so far seen a nice white,grey 32gtr,nice 33 and a phat purple 34 gtr in morayfield looks like I've moved to the right area.
Not many on the road though really. Fair few non GTR's around though.
Just be careful where you park at night, If you do not have an Alarm fitted I suggest you chat with Chris from Audio Express he looks after the SAU boys and is a club sponsor.
Chris does good work :thumbsup:
Too much Salt, not enough good driving roads.
Too many racing Patrol's :glare:
Will keep that in mind once the girls up and running bro,be good catch up and meet some the Boiz round this area aswell just to get to know them all.
Sounds like a plan, how much love is your car in need of?
What ecu is it Zeke?
XD at the best of my knowledge my 33 is granny spec when it comes to power mods just got aftermarket ecu, and pod filter and im lucky to get 400km from a full tank.
Aftermarket zaust sorry not ecu and aftermarket intercooler. Derp a derp.
Afternoon all :)
full rebuild bro going all out on the build to hit the 600+mark,rpm said ill hit that easy with what I got
nice, I'll stay in the low HP club :( you guys can go play.
still be good catch up with the Boiz and organise a cruise or meet up thou just interested meeting the local nissan fanatics round morayfield/caboolture area.just moved here from NZ
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
