Afternoon all :)
Here's to Friday! :cheers:
Wow didnt realise there were so many here,so far seen a nice white,grey 32gtr,nice 33 and a phat purple 34 gtr in morayfield looks like I've moved to the right area.
Not many on the road though really. Fair few non GTR's around though.
Just be careful where you park at night, If you do not have an Alarm fitted I suggest you chat with Chris from Audio Express he looks after the SAU boys and is a club sponsor.
Chris does good work :thumbsup:
Too much Salt, not enough good driving roads.
Too many racing Patrol's :glare:
Will keep that in mind once the girls up and running bro,be good catch up and meet some the Boiz round this area aswell just to get to know them all.
Sounds like a plan, how much love is your car in need of?
What ecu is it Zeke?
XD at the best of my knowledge my 33 is granny spec when it comes to power mods just got aftermarket ecu, and pod filter and im lucky to get 400km from a full tank.
Aftermarket zaust sorry not ecu and aftermarket intercooler. Derp a derp.
Afternoon all :)
full rebuild bro going all out on the build to hit the 600+mark,rpm said ill hit that easy with what I got
nice, I'll stay in the low HP club :( you guys can go play.
still be good catch up with the Boiz and organise a cruise or meet up thou just interested meeting the local nissan fanatics round morayfield/caboolture area.just moved here from NZ
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
