Hi Guys,
Im selling my Calais Turbo that I bought nearly a year ago, I miss my bikes and want to get back into it and Im looking for a 1000cc sports bike or swap for another car. If youre interested in swapping drop me an email. Im not sure if my cars an original turbo or manual if you gurus out can tell me.
Vehicle Registration WRA322
VIN/Chassis Number AVL026902A
Engine Number 026705A
Vehicle Make Holden Calais Turbo
Vehicle Colour Gold
Body Type Sedan
Year of Manufacture 1986
Registration Status CURRENT UNTIL 17/12/2011
Transmission 5 Speed Manual
Odometer Reading (will check tonight)
Interior Extras
Pioneer MP3 Player (Door Pods)
Pioneer Front Splits
Sony 6x9 Rears
Boost Gauge
Retrimmed Interior (Leather/Vinyl)
Interior Plastics Painted White
Exterior Extras
19 VY Signatures
Front Mount Intercooler
Car Paint In Good Condition
Recently Replace Bushes, Front Disc, Bearings
Thats all I can think of at the moment.
More Pictures Can Be Found On
http://s1137.photobucket.com/albums/n505/huymanturbo/Calais%20Turbo/
Contact Huey (I work night shifts and can reply back to your emails via my blackberry)
Location Epping
Email [email protected]
Price $8800 NO RWC Negotiable or looking for SWAPS
Edited by billyz
https://www.sau.com.au/forums/topic/357552-fs-vic-gold-calais-turbo/
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
