Hey Guys
Been a while since i checked in. I was thinking of selling my Pop charger + Z Tube.
SInce i'm not really aware of the current market price, i just wanted to know if anyone is actually interested in buying it.
But i I know the rule is to specify a price, so honestly, i'll be happy with $150 for both. I'll also throw in a set of K&N Filter oil and charger with it. You'll also get the heat shield which i've used from day one.
Currently it's still hooked up in my car.
The pop charger itself has dents because of shipping damage when i bought it from the states but it dodesn't affect performance.
Perth pickup is preferred cause you'll spend heaps just for delivery.
Check the pictures out and throw me an offer guys.
Here's my mob : 0401802149
Doddy
https://www.sau.com.au/forums/topic/357613-eoi-jwt-popcharger-z-tube/
Not really. You do hear the difference in the engine tone.
But from outside you can definitely hear the difference. And at 4k+ rpm, there's a hiss that it makes. Kinda awesome. I'm gonna miss it hehehe
I would have definitely grab them straight away if I wasn't spending money on other parts of my car now. Plus, I rarely take it over 3500rpm. :P
I can vouch for that sexy hiss sound that comes from pop charger. I think Steve got the same combo and the sound was very nice. :thumbsup:
Good luck with the sale, Doddy.
I'm putting everything back to stock. Even my springs. Over the modding phase I guess..
Install is easy once you've done it a couple of times.
Edit: come to think of it, it's actually easy from the start. With the right guide, anyone can install it :D
Edited by dodes47
You willing to ship to Sydney? If yes, how much?
Hey Guys
Doddy
Keen on selling your springs? im currently looking for some atm to lower my v.
Sorry mate, they're sold.
I think so. Let me get a proper dimension and weight of the package so i can give you a quote on postage. I'll get back to you soon.
Cheers
  • 3 weeks later...
Ok. Sorry i haven't been able to update the shipping price. been busier than a one legged man in an ass kicking contest <---- Found that on Google :banana:
Shipping is $25 Regular Anywhere in AU
So take it off my hands please people..:thumbsup:
  • 3 months later...
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
