OEM r33 S1 plastic grill, broken clip in the middle and the bottom clip on drivers headlight (doesnt effect it) , no S badge
$50
OEM r33 S1 rear seats, good condition. no rips / tears,
$60
r33 stockies. all 4 with different types of tread but enough to pass a roady. wheels in good condition
$140
r33 AC. includes everything from the engine bay.
condensor, front fan, lines, silver can, compressor and bracket to bolt to block & screws. condensor in good condition, very minimal bent fins. (can get a pic if requested)
$110
OEM r33 S1 rear wing, missing the rear brake light cover
$20
r33 front strut brace
$50
justjap rear monkey brace, can get a photo at request but they all look the same.
$80
turbosmart 2stage boost controller
$50
600x300x75 bar and plate intercooler core, brand new in the box.
$100
fire extinguisher, including everything pictured + mounting hardware
$70
18x8j , probably high +30 - low +40 offset. little bit of gutter rash around the rear wheels as pictured
2 with good tread, 235 (triangle brand tyres) $130
2 with very minimal tread. $70
or take all 4 for $180
Selling my built sr20 engine, with 0km on it. Includes
Tomei camgears
Tomei ras
Tomei 260 intake cam/ 270 exhaust cam
Tomei solid head
Supertech dual valve springs
Supertech ti retainers
Nismo thermostat
Exhaust side port and polish
CP 86.5mm 8.5:1 pistons
BC H beam rods
King pro bearings
ARP head, main & rod bolts
Cosworth metal HG
Greddy style 5L sump
Rocker cover modified with x2 -10AN fittings welded on the rear and -10AN fitting welded on the side.
Chemically cleaner
Bored & honed block
Balanced & blueprinter
All the usual prep work
Engine has cost me more then an addition $2,000 of the asking price to build
Selling for $7,000
complete standard rb25det package minus turbo from a s1 r33.
purchased and installed by justjap on 11/12/09 (1 year 2 months ago) and has since put 31,000km on the engine. I also have the purchase and install receipt from justjap.
includes throttle body, intake manifold, injectors, rail, reg, complete running motor with accessories; p/s, alternator, exhaust manifold, engine mounts, coilpacks and ignitor, loom and standard ECU. rb25 gearbox with no crunches. includes a short shifter, box mount, clutch slave cylinder, heavy duty clutch of some sort.
Engine runs fine with no issues, blows no smoke. Can be seen running before it is removed from the car.
$2800 with everything
$1600 without gearbox
cant decide whether to keep my sr or rb so what ever sells first can go.
Located in wollongong.
pm or sms 0416 129 811 for any more details.
