Stock parts for sale with details below:
Airbox - 70$
Genuine Skyline Strut Bar: 120$
Stock Intercooler: 70$
Series 2 Spoiler: 70$
Series 2 Boot: 50$
Dump Pipe: 30$
Front Pipe: 20$
Stock Springs: 10$ each x 4 = 40$
Contact: 04211 45480 or pm here
Happy to post at buyers expense.
If anyone is interested in a 3.5" HKS Super Dragger catback stainless steel exhaust system or a 4" Tanabe catback system, please let me know. I will be posting a new topic with pics of them soon.
https://www.sau.com.au/forums/topic/357645-r33-gtst-stock-parts-sale/
  • Replies 44
airbox sold pending payment...
the following are still available..
Series 2 Boot: 50$
Dump Pipe: 30$
Front Pipe: 20$
Series 2 Boot: 50$
Dump Pipe: 30$
Front Pipe: 20$
airbox sold!
rear strut bar sold pending payment.
Series 2 Boot: 50$
Dump Pipe: 30$
Front Pipe: 20$
Edited by myskyride
airbox sold
rear strut bar sold
Series 2 Boot: 50$
Dump Pipe: 30$
Front Pipe: 20$
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
