Stock parts for sale with details below:
Airbox - 70$
Genuine Skyline Strut Bar: 120$
Stock Intercooler: 70$
Series 2 Spoiler: 70$
Series 2 Boot: 50$
Dump Pipe: 30$
Front Pipe: 20$
Stock Springs: 10$ each x 4 = 40$
Contact: 04211 45480 or pm here
Happy to post at buyers expense.
If anyone is interested in a 3.5" HKS Super Dragger catback stainless steel exhaust system or a 4" Tanabe catback system, please let me know. I will be posting a new topic with pics of them soon.
https://www.sau.com.au/forums/topic/357645-r33-gtst-stock-parts-sale/
  • Replies 44
airbox sold pending payment...
the following are still available..
Series 2 Boot: 50$
Dump Pipe: 30$
Front Pipe: 20$
Series 2 Boot: 50$
Dump Pipe: 30$
Front Pipe: 20$
airbox sold!
rear strut bar sold pending payment.
Series 2 Boot: 50$
Dump Pipe: 30$
Front Pipe: 20$
Edited by myskyride
airbox sold
rear strut bar sold
Series 2 Boot: 50$
Dump Pipe: 30$
Front Pipe: 20$
