Hey hows it going, i got a R33 GTS-t S2, which is currently tuned on a SAFC i got full exhaust except dump pipe, front mount, apexi afc and pod filter so just the usual mods its currently tuned for 12psi and 98 octane.
Now i recently got it tuned and it feels much better and responsive and ive experienced better fuel economy however, i did have a rough idle which i fixed with a set of spare coil packs lying around and i had some miss fires in the 4-5k rev range which was solved with the change of coil packs.
But i have this problem every time im on the free way cruising at a 100 when i open up the throttle a little it has this sort of hesitation to go and sort of feels like sometimes its loosing power now im not sure what would be the cause of this problem as i have no air leaks or anything and i don't experience it cruising under a 100 or planting it over 100.
But just roughly when staying at a certain rev over 100 or at a 100 and open the throttle up a tiny bit it has that tend of hesitation. Now could this problem be due to the coil packs still or would it be worth while to invest in some split fire coil packs or could this down to another problem.
I got another question what color should the transmission oil be and roughly at how many intervals should you change it.
Yours Truly,
Nick
By transmission im guessing u mean automatic. It should be red. Or still have a red tinge to it. If it smells burnt and is getting dark or black then u might have issues.
Servicing shoukd be done every 60000 or when required by condition of fluid.
The freeway issue sounds like a small problem with the tune.
Try it in a lower gear. Sit in 3rd at 3000rpm or what ever ur car sits at on the freeway. And see if it happens.
Might be rpm related
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
    • @Stringycheese  Have you only gone to the one blue slip workshop?  There will be a heap of them where ever you live, good odds that the next place you go to will pass the car.  Unfortunately (or fortunately?) every blue slip / engineering workshop will be different and will be happy passing or failing different things - despite working from the same set of rules. It's kinda like 2 lawyers arguing over a piece of legislation, each saying their interpretation is correct. Might seem strange that this happens when it comes to getting a modified car passed, but this is very much a thing. A big part of the game is finding an engineer / workshop that is on the same page as you.
    • Bah. I daily mine. ~60km per work day, 10-12 thousand km per year. What's the point of having a dirty old Datto and leaving it in the shed. It needs to be driven and enjoyed while the govco allows us to do so. It will only be a few years before we're forbidden to even start up internal combustion engines.
    • Judging by that spring perch and the normal looking spring on it - not a coilover. Well.... it is a coilover, just a stock format coilover, rather than what everyone calls a coilover.
    • Yes it is. We get stock from Nismo directly. I'm happy to take photos/video of it as proof before I ship it with timestamps or whathaveyou.
