motor is a S1 stagea (non neo)
car is a s1 R33 gtst
ok so has anyone done this? if so how did you go about the oil pickup positioning?
the plan was to use my sump and bolt it onto the stag motor, but they aren't co-operating
the pickup is in the wrong spot :/
https://www.sau.com.au/forums/topic/358308-stagea-rb25-into-33gtst/
custom pickup in the base of the pan approx 1-2 inches back from centre....tube exiting the side of the sump to a fitting (-8 or similar), then hose from there to the exhaust side of the pump where you have to remove a welch plug and tap a thread. Put a -8 or similar AN fitting in the side of the pump and join that hose. Tap a thread in the back of the pump where it normally sucks the oil in and put in a flat blocker or welch plug. DO NOT WELD IT or you will distort the pump.
Job done
sorry I forgot you are going the other way. You should be able to just make a custom pickup using 16mm stainless bends and keep it all inside the sump (if you are using the tin sump)
If you are going the other way, the external method is the only way because of the position of the driveshaft through the centre
Just gotta make sure the height of the pickup is ok and not too close to the pan floor, also not too far away. 5-10mm from the entry should be ok.
Also with the added length you may have issues with vibration in the tube so get them to re-attach the other mounting strap that is on the stag pickup. It will strengthen it
so measure the height that the current one sticks out of the block, weld it, keeping bends minimal, attach secondary strap... done...
will post results when done aight
:D
going to try leaving the stagea pickup in it's standard spot and cutting out a hole in the RWD sump's splashguard.
(providing the height of the sump's are the same and not deeper/shallower)
can anyone think of a reason why this could fail?
i'm thinking i might just cut the stagea sump and use that...
i was reading a thread about RB26's into s13's and everyone seems to just cut the 26 sump and use it, as they get the stronger sump and less hastles
as far as I can see this is exactly the same scenario.
gonna ring trent and ask him today as he has already done this on cat's race car
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
