Hi guys
Just spent several hours reading up on old threads of the wonderful world of cooling problems in Skylines... :whistling:
But couldn't find many similar incidents to mine (the few that looked similarly didn't have much info on it).
Background info
I had 2 past cooling system related problems.
1st incident occurred early February after getting my A/C fixed, I noticed a slight over-heating (stock temperature needle went slightly over 1/2 way), noticed coolant was bubbling when I granny-ed back home. Got it checked out & turned out to be a worn-out thermostat & Radiator cap, replaced both & car seemed fine (needle always stays just below 1/2 way point).
2nd incident occurred about 2 weeks later, the top plastic radiator tank has developed a hair line crack & pissed out a little bit of coolant, took it to the local mechanic and got a reconditioned top tank fitted (thought about using a new OEM one, however lady on the phone from Nissan couldn't find one for a automatic Skyline).
The issue
Ever since then I've kept a close eye on the temperature & cooling system & it appears that the coolant level is going down at a very slow rate from the reserve bottle. I've marked the bottle & it seems to be losing a coupe mm down the marked line every time I check it (every couple of days in the morning when the engine is cold). The actual radiator is always full with the coolant level up around the neck area.
It has being about a month & the coolant level in the overflow bottle has gone down from about ~80% (between the min & max line) to ~60%.
Last week I took the car to Natrad, they pressure tested the system & didn't find any leaks & it held a steady 15psi with no drop in pressure. Also I haven't seen any of the usual head gasket issues (oil is nice golden colour, coolant is nice green, no white smoke or bubbles from radiator, car hasn't over-heated).
So now I'm stuck on whats causing the coolant level to drop ever so slight from the overflow bottle, only thing I can think off now from reading some old threads on the issue was that it could be some air that wasn't fully bled out when the new top tank went in & is ever so slowly coming out & hence slight drop in coolant levels? (how long does this take anyway? Since it has being a month already.)
Is there anything else I should look at?
Cheers
EDIT: Also noticed the replacement rad cap they put on was some generic one which didn't state the pressure, all it had was the number "130" written on it, does that mean its 1.3 bar cap? After reading some extra info here, I'm thinking off buying new OEM 0.8 bar cap from Nissan later this week (which hopefully doesn't cost me an arm like what they tried to charge me for a plastic bottle cap for the window washer bottle).
Edited by Mayuri Krab
https://www.sau.com.au/forums/topic/358398-reserve-bottle-coolant-level/
You can get a rad cap from supercheap or something, don't pay for an OEM one :P
Coolant level dropping means you are losing coolant somewhere generally. you can bleed the system properly with the bleed screw up the top near the throttlebody, loosen it all the way until either bubbles or water come out (might want a toewel to mop up the mess).
I guess it would only take the smallest leak to do what you are describing - maybe it's only evident when its warmed up.
How much torque do you need to move that bolt?
Was trying this morning but the bitch won't budge at all! I'm using some generic spanner & anymore force I apply I feel that I'm going to snap either the spanner or the metal joints that connects to the bolt...
Also every time I start the car up & drive it for the 1st time or so I can hear a "Glup" noise behind the dash (comming from the front of the car), could that be the air stuck in the cooling system?
Since I can't seem to undo the bleeder bolt, I followed what someone else suggested on an old thread & parked the car on my steep car park with the front end on the high ground & let it idle with the radiator cap off till the engine was up to operating temperature (aftermarket gauge showed it was at the mid 80 degs) but no bubbles ever came out.
While I was doing this, the coolant keeps on raising above the neck of the radiator & flowing out & splatting onto the clutch fan (which ended up on my face... :whistling: ). Is this normal?
The glup sound you are hearing i believe is the airconditioning motor that selects where the air is directed to.
It might have lost a tooth in the motor.
Common r33 problem i have read.
Edited by Socrates
Hit the bolt with some penetrating oil like wd40 and let it sit for a bit
maybe tap it with a hammer...
its just rusted inside and seized.
As far as I know, coolant coming out of the rad means it's having issues flowing, like its pushing water into the rad but it can't flow out back into the engine. This can be caused by airlocks, happened to me on my rb buggy.
Definitely need to get that bleed screw undone first. brace the bracket with something and get a breaker bar on it.
Will try the wd40 tomorrow, can't believe I didn't think about that! I was even using that stuff to on Saturday cleaning off some rust in the back boot.
Finally with the min & max line on the bottle, is the max for when the coolant is cold or when it is hot (engine at operating temperature?) on the old threads there seem to be a conflict of answers...
When it's hot it will be at its fullest, pretty much when you turn off a warm car your coolant will be at its warmest as it's not being cooled/circulated, so it will increase the pressure in the system and flow out the rad into the overflow. As it cools down the water gets sucked back into the rad.
Tbh I don't understand how the coolant can flow back in, never really thought about that - surely it gets stopped by the rad cap... maybe it only sucks back in while the pressure is still high enough to open the cap.
Really don't think it matters how high the level is on the overflow, as long as there's enough. If it's too high while cold it could overflow once warm and come out the overflow bottles overflow part. dawg. just my 2c of course not very informed on this topic
The glup sound you are hearing i believe is the air conditioning motor that selects where the air is directed to.
Does the motor move even if I have the entire system off?
Since mine still makes that 'gulp' sound shortly after I start the car even if I have the entire air vent system off.
Update
I started to notice some small coolant marks on the undercover of the car so I had a more through look around the engine bay & noticed a trail of coolant marks on the areas underneath the water pump.
I guess the water pump seal is gone & it's new pump time, dam Murphy's law is coming back to bite me in the ass now. :glare:
While the pump is getting changed I guess I will also get the bearings/pulleys changed too at the same time (timing belt was done 30,000kms ago).
I'm going to be poor again... :(
Noob question:
When your water pump seal is gone, how fast is coolant suppose to leak from the hole underneath the water pump, Driping or pissing out?
My leak seem to only occur when the car cooling down or warming up, doesn't seem to notice any leaks when the engine running at operating temperature?
Noob question:
my pump leaked out of the tell tale hole twice in 3 months while it was parked up for 2 weeks each time when i was away working. the day i finally saw it first hand it was a fast drip almost a stream. must depend on pump position when engine is stopped. never leaked when running
Got my car back with new water pump, idler bearings & 3 new drive belts. No more leaks from underneath the pump.
With some luck, hopefully no more other leaks/problems would occur in the near future, as I need to drive to Albany this coming easter...
<fingers crossed>
Quick question for everyone:
What level does your coolant sits at in the radiator?
Mine always seem to settle about an inch below the neck. Is that normal?
If I top it up all the way to the neck, after a drive & letting it cool down all the way (next day) it will be back down to this level again. I don't think its leaking anywhere since I had it pressure tested just a week ago & the shop reported no leaks & it seem to be maintaining the coolant at this level for almost a week now.
Just a bit paranoid with the recent cooling system issues I had...
Hey guys, need your help/opinion again, sorry
So after my last fix (replace the O-ring seal on the top radiator tank due to a minor leak) I drove the car to Albany (~400km) before Easter break & it had no problem (& I give it a bit of WOT from time to time when overtaking road trains & Caravans).
For the past week the car has just being mainly sitting there, with the exception of 1 trip I made to Denmark (~100km round) I checked the overflow bottle level from time to time & it appears to be stable around the max mark (when cold).
Today before heading back to Perth I did one last routine check before handing out & I found what appears to be a white/semi-transparent film on the top layer of the coolant in the overflow tank (see picture below), I checked the coolant in the radiator & it doesn't have the same 'film layer' there.
What is this film? Is this what oil in coolant looks like? Did a a couple of google image searches but those appeared to be more browny cream colour instead?
I checked the other usuals (oil dipstick, oil cap & auto trans dip stick) & all of those appeared normal and rad cap doesn't have white stuff neither.
While driving the car back to Perth today, keeping an eye on temperature & it was all normal (never went past 82 deg C when stationary, usually sits in the low 70s when moving along at 100-110km/h) & nothing was unusual here, car was smooth (no misfire) even when I go WOT (when overtaking) & hit 6k rpm etc etc
I also pulled over & checked the coolant bottle every 100km or so & nothing else was unusual, I noticed that once the coolant has warmed up the white film disappeared & I could only spot some small 'white flakes' if I flash a LED torch.
So yeah, is that white film what oil (or ATF) look like in coolant?
Cheers.
Going to check it again 2morrow, this car is giving me a headache atm :dry:
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
