hey all im wrecking a crashed nissan r33 s1 most parts are ready to go but some are broken from the crash. im in cliftonsprings about 15 min out of geelong but i work at avalon airport so if you need somthing i can take to work and you can pick up thats no problem. i have sold the diff and gearbox already. the car has had a hard hit in the drivers side rear wheel from a power pole. have the rest of the parts ready to go the motor is out and most of the car is striped. 130km on the engine the owner of it said it was well serviced and looked after. please send me a text mesage with what you want as ill be in the shed all day pulling the rest apart and ill get back to you. i have already made my money back so parts wont be to pricey. i am after $1500 for motor. its on the crossmember still with full wireing loom turbo and manifolds or send me your best offer first in gets it lots of good parts left!! cheers sam.
call 0425717785. thanks heaps
too many parts to list!!!!! very cheep prices
hey mate im interested in the front reo bar..... how much you want for it?
hey mate yeah you can have the reo bar for $80 shoot me a text mate 0425717785 sorry for late reply still getin the hang of this lol
whats the colour of your car ?
hey there mate its a white one.... i have drivers mirror passanger front door bonnet and passenger front gard. the shell has already gone cheers
hey mate i just checked it out. it is a little bent but not creased it would be fixable. send me a message requesting a pic and ill show ya the damage. its not bad. if ya still keen you can have it for $30. cheers mate
do you have aftermarket exhaust mate
its just a standard exhaust system with a hot dog welded in. its alitte bent from the diff back. but would be ok if some ones after a stock exhaust for a roadworthy or somting. $50 if any ones keen cheers.
  • 2 months later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
