Its a girl (again)
Thanks Andy :)
Following closely behind Matt (Bugalugs) Deb & Tayah!
Tania started contractions around 7.30am Monday morning, & finally @ 6.10pm that evening little Jasmine Emily was born :) :) :D Jasmine weighed in @ 6lbs8, was "also" 49cm long, & very close to 33cm head circumference!
Mum & bub are both doing really well :)
Bug's & I both with the first name Matt, both with R33 GTS25t's, & both have girls nearly identical in size!
https://www.sau.com.au/forums/topic/3585-its-a-girl-again/#findComment-59420
Originally posted by whatsisname
Thanks again guys :)
Shell,
         Don't do it girl! You'll end up watching all the crap on TV @ 3am in the morning :):D
Congrats Matt! :)
Jasmine was top of our list if we had a girl.
How bad is the TV dark o'clock??? :confused:
heh, now I offer to do the feeds only when RAGE is on :(
https://www.sau.com.au/forums/topic/3585-its-a-girl-again/#findComment-61957
Choosing a name you both like isn't easy hey!
Tania didn't want to know if it was a boy or girl till the actual day! Lucky it was a girl 'cause we were both set on the name Jasmine from the start :) A boy named Jasmine….hmmm.
The child restraints "may" get used in the Skyline, but it's unlikely. The RAV4 does all the domestic duties :)
Free to air TV in the wee small hours is pretty dodgy stuff :D Yeah RAGE is one exception, good thinking! Oh, & F1, MotoGP, Indy etc... Mind you those don't really qualify for "dark o'clock".
Cheers & thanks again :)
https://www.sau.com.au/forums/topic/3585-its-a-girl-again/#findComment-62291
Originally posted by red900ss
heh, now I offer to do the feeds only when RAGE is on :)
haha Dino you can't just do the weekend shift - that's not fair!!!
the weekday line up is very sad :D
although on Thursdays they have that crap they call football on at about 2.30am (AFL footy show).... oh oooops I'm in the SA section *they like it here*
/runs and hides.... :) :)
https://www.sau.com.au/forums/topic/3585-its-a-girl-again/#findComment-62296
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
