Hey guys ive collected a fair bit of crap lately so its time to have a clean up.
First up ive got a trust gearknob from my old car, real heavy with a few scratches but nothing too bad $30
Next is a silicone intake pipe for r32/r33, never used it and never will $50
R32 hicas pump and some lines, still in good working condition just removed everything as i have a hicas lock bar Make an offer
R32 GTR maybe r33 GTR? Front pipe section, looks aftermarket not sure dont have a gtr so dont need it $50
Shift light, dial on the back you can set from 0-11000rpm should work on any car just needs power and speedo signal wire $20
R32 dash cluster surround, perfect condition top part but the bottom part has a hole cut for a small aftermarket gauge $50
R32 straight pipe with one ressy from front pipe back will probably fit ceffy, laurel, r33 just do your reserch $150
R32 standard suspension front and rear good for regency $200
R32/r33 aftermarket front suspension, springs are red and legal height but lower than stock $50
Also have a genuine TRUST cat back exhaust on my r32 4 door at the moment but it was on a gtr. Jasma approved and legal decibel as im about to go through regency with it, it will be up for sale in about a week an i want about $350 for it,
May add a few more things as i come across them, cheers
https://www.sau.com.au/forums/topic/358556-clean-out/
  • 1 month later...
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
