the free version of fraps is not worth it. its much easier to just buy the $47 lifetime license.
also, you will need some form of video editing software, something like corel visual studio if you want fancy stuff. but i imagine windows movie maker might do the job. as the raw filesizes for the fraps recordings range from ~400MB for a 10sec clip, to 3.9GB for ~ 2min clip, so you'll need a good chunk of free hard drive space.
reason why they are so big is that the recorded files are raws ( i.e fraps does not have enough time to encode it) thats why you use the video editing software.
this was recorded with fraps. converted to .flv format in corel visual studio and uploaded to youtube.
total filesize for the above video was around 90MB if i remember corectly.
or this .mpg clip of Need For Spee d: Hot Persuit. the total fizesize is 151MB. but the original files were around 12GB. so i usually render in .mpg if i can.
http://hotfile.com/d...28nov2.mpg.html
Edited by liger
i use the free version of fraps and caught a team killer the other week in world of tanks
your very right with the raw file sizes being extremely large
i used corel Video studio to edit and also upload to my youtube seamlessly
the only problem with free fraps if it only records for 30secs then you have to press the record button again and miss a second of the action
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
