Hi,
The R30 has been sitting in the yard for two weeks. Usually it starts first time, even after many weeks, however now it fires for a second or two and then dies. After that nothing, the engine just turns over.
If I wait a minute, switch ignition off and then try again, it does the same thing, fires for a second then dies.
I can hear the fuel pump priming. There's fuel in the tank and the fuel filter is full of fuel so the fuel pump is working. There must be some spark because it does fire briefly. Coil is new, and the new coil gives same symptoms as the old coil. No obvious leaks anywhere, battery is fully charged. I recently replaced the temperature sensor and cold start valve (with parts from wreckers) and car was running well when last used.
Any thoughts on what to check next?
JH
https://www.sau.com.au/forums/topic/358885-r30-wont-start/
Id also check if the injectors have leaked and then gummed up (fuel tyurned to varnish like substace) and now blocked.
Same thing happened to me!
It would run for a few seconds then just die.
I found out the cold start injector (the agricultural irrigation like fuel injector in the intake plenum) was spraying enough fuel during cranking to actually get it to run. Once the starter motor stops the cold start injector stops too.
Maybe test it out by un-plugging the cold start injector (simple clip on plug) and see what happens.
https://www.sau.com.au/forums/topic/358885-r30-wont-start/#findComment-5735215
Thanks Andrew,
I'll unclip the cold start injector and test your theory. Is it likely that all the injectors would gum up? Maybe the relay is faulty.
@Peter, I think the dizzy/ignitor is OK. It's the 'newest' component on the car.
https://www.sau.com.au/forums/topic/358885-r30-wont-start/#findComment-5735290
Thanks Andrew,
[/quote
I have just been thru this.
Get some throttle body cleaner. Clean the AFM and the throttle body. Worked for me. 100%
https://www.sau.com.au/forums/topic/358885-r30-wont-start/#findComment-5735859
That did the trick (plus a new fuel filter). Back on the road.
Thanks for all the replies.
JH
https://www.sau.com.au/forums/topic/358885-r30-wont-start/#findComment-5739298
Hi Socrates,
I suspect the fuel filter was the main problem. The throttle body was very dirty so cleaning that must have helped. As for the AFM, it was reasonably clean but I also cleaned up the electrical plug and connectors.
The problem with EFI is that a fault in any one of the sensors, relays, connectors (or an air leak!) can cause problems or stop the engine from running. I collected a set of relays off a wreck today - just in case (!). I probably need more testing tools, a fuel pressure gauge would be useful - for a while I thought that the fuel pump wasn't delivering enough fuel.
JH
https://www.sau.com.au/forums/topic/358885-r30-wont-start/#findComment-5739405
I can confirm that there has been alot of problems with fuel since the floods in qld. I know of at least 6 cars now that have crapped themselves due to fuel. Tank clean and new filter, and purged lines have fixed them all.! (including my R30 Hatch which is in Brissy at the moment)
https://www.sau.com.au/forums/topic/358885-r30-wont-start/#findComment-5740330
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
