Neighbour came knocking on the door tonight, says the lights on the car are doing weird things. I go out, and they are, rear lights and at the front, flashing between high beam and the fogs .... not bright, just dim like there's not much power. And there's not either, not enough power to open the doors by remote, or turn over the engine. So I've disconnected the battery, but now what?
I've looked at this post http://www.skylinesaustralia.com/forums/topic/343588-possessed-lights/page__p__5540346__hl__battery__fromsearch__1#entry5540346
but today has been one of the driest, sunniest days here in Melb for a long time, and there's not even a hint of moisture in the battery compartment. I didn't have the car today, my wife was using it, but it doesn't sound like she was doing anything unusual with it, certainly been no warning lights on recently.
I'm presuming it will go again with a jump start, once the RACV get here, but any ideas as to the cause? It's an '04 300GT sedan.
Cheers,
Richard
https://www.sau.com.au/forums/topic/359136-battery-dead-lights-flashing/
new battery for a start. they are data driven and once teh battery diesthe CAN system goes into no mans land and has a freak out session.
start there and forget a jump start.
Thanks Chris, will do.
Is battery death in these always that sudden, or should there have been other signs?
there is not a science to it.
IF you are lucky the car will be slow to start otherwise it will simply die. average life of a battery is 2-3 years at best. if in doubt - change it.
So when the car comes back to life it 'knows' where the windows are. You know that little automatic adjustment your car does when the door closes? Yeah you need to reset that.
Put window down, put window up and hold the up button for three seconds at the top, put the window back down. You should be good.
Just curious,
i changed my battery last week and read you needed to make sure the windows were all the way down before disconnecting...why?
So that process of "put window down, put window up and hold the up button for three seconds at the top, put the window back down" is after disconnecting and connecting it back?
Hmmm cant say i did that exact procedure,
but as far as i can tell windows go up/down fine and still do that lil kick at the end.
Well I got the RACV to jump start it this morning anyway. Seems like the fog lights had been switched on accidentally, which obviously did the battery draining trick. Guy said the battery was still very healthy, so I'll just leave it and keep an eye on it for now.
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
    • Thanks mate, well done to you too! Yeah not looking forward to doing any major work to it!
