Selling off a heap of stuff I dont need due to upgrades, cars being sold etc
Xforce RB26 dump pipes, used for approx 18 months on a race car but no damage, no cracks worked fine $200
Xforce front pipes, 2 3/4 inlets flexi joint and 3 inch outlet, again same as the dump pipes in condition $250
R32 strut braces front in chinese rear is cusco. Put a cage in so no longer need them $150
HKS GTRS turbos, require rebuild, comp wheels ate a silicon hose and bearings are gone $200
R32 rear hub bearings, brand new ready to install, upgraded to centerlocks so no use for them $150
S13/R32 non hicas rear toe arms, cusco branded good condition unsure of age but work fine $80
RB cam gear, 1 only was on an RB25 exhaust, enging is gone have this left over $60
RB30 bottom end, complete has fresh bearings, pistons and rings, crank linished and assembled. Unsure of previous history but the pistons are ACL as too are the bearings. I have no use for it so taking up space $300
Everything is in sydney and can post SMALL items only otherwise pick up any time is fine
Photos to come tonight
No low ball offers I wont bother responding as I dont have the time
https://www.sau.com.au/forums/topic/359605-rb-and-skyline-parts/
Brand new aeromotive A1000 fuel pump. Never fitted or used. bought it for a car im building but now have a good deal with another manufacturer so I use their products instead. Perfect condition never used $350
Brand new Aeromotive fuel filter. 110 micron same deal as the pump never used or had fuel in it. Perfect for E85 $120
