I have some photos from Motorkhana yesterday. I think everyone from SAU that had entered have seen the photos already, so here they are for those that have not. Next one is in June.
Reese back in a R32.
It was a "Professionally lowered" car in the forsale ad :P
Auto Spoiler
Standard Micra with Wheels and stripped interior.
https://www.sau.com.au/forums/topic/359818-photos-from-motorkhana-yesterday/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
