Item:
Set Rays Gram Lights 57c, front white, rear gold. 17x9.5 +12, 18x9.5 +12 $1800
Set Work Eurolines, 19x9.5 +12 19x10.5 +18 $1900
Set R32 GTR wheels, perfect condition, advan semi slicks all round. $800
Pair Volk GTV 18x10 +5, perfect condition. $1300
Tomei V35/350z 2way diff in housing, 3.9 central20 diff gears. $850
Nismo R32 skyline 2way, in 4.3 non abs housing, 5 bolt shafts. $800
Blitz 100mm sidemount intercooler, suit s13/r32 stock position. $150
5 stud front hubs, s14 brakes and rotors. $400
s13 sr20det engine suit rebuild. unsure of condition but not good. complete with inlet/exh/turbo etc all still attached. $400
R32 GTR late model gearbox, minus transfer case, good for gearset for busted rb25 box. $350
vvti 1jz long motor, comes with engine mounts, coilpacks, front sump. low km jzx100 motor. $700
ARE cooling surgetank, twin outlet, all speedflow weld ones. $250
R33 GTR rear cradle, complete with arms and knuckles, no diff/shafts/hubs. $200
R33 GTR side skirts. series 3, $150
R33 GTR front bar, series 3 front lip, genuine plastic. $600
S15 trial front bar. white, good condition. $50
Rb25 series2 splitfire coilpacks. $350
brisbane
Item Condition:
all good
Reason for Selling:
excess stuff
Price and Payment Conditions:
as listed, cash.
Extra Info:
Pictures:
on request.
Contact Details:
buckna. 0427282562
https://www.sau.com.au/forums/topic/360124-parts/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
