here is another updated list of parts left - i still have more to add :)
please note reduced pricing as hightlighted in red!
1. gearbox - $750 PRICE DROP $700
2. front door trims - $200
3. rear door trims - $170 PRICE DROP $150
4. dash cluster with 180km/h speedo (showing 73000km) - $150 PRICE DROP $130
5. doors (includes tinted glass & power window mechanisms) - $320 PRICE DROP $300
6. front windscreen (with antenna) - $150 PRICE DROP $130
7. rear tail lights - $160 PRICE DROP $130
8. factory afm - $50
9. blitz icolor dual solenoid dsbc boost controller (with user manual) - $600 PRICE DROP $570
10. attesa 4wd pump - $350 PRICE DROP $300
11. input shaft for transfer case/4wd - $50
12. work wheel nuts - $120 PRICE DROP $100
13. hicas pump - $120 PRICE DROP $100
14. ohlins suspension, very nice ride & not too hard/bumpy like most coilovers - $400 PRICE DROP $350
15. rear subframe 'pineapples' to lock in blown out bushes & stiffen rear end - $70 PRICE DROP $50
16. spare wheel - $50 PRICE DROP $40
17. dash vent (passenger side) - $50
18. left cv with knuckle assembly - $150 PRICE DROP $120
19. right cv with knuckle assembly - $150 PRICE DROP $120
20. drivers side window/mirror control - $80 PRICE DROP $70
21. sun visors - $30
22. complete boot trim - $160 PRICE DROP $120
23. instrument panel surround (does not have headlight switch & wiper button) - $40 PRICE DROP $30
24. power steering line - $40 PRICE DROP $30
25. caster (radius) rods (bushes are good) - $80 PRICE DROP $60
26. radiator overflow bottle - $30 PRICE DROP $20
27. passenger & drivers side door sill garnish - $80 PRICE DROP $60
28. door seal finish - $30 PRICE DROP $20
29. factory side skirts (black) - $180
30. front subframe - $60 PRICE DROP $50
31. bootlid rubber seal (no tears) - $30 PRICE DROP $20
32. power steering reservoir - $20 PRICE DROP $10
33. earls braided brake lines (front and rear) - $120 PRICE DROP $100
34. factory blow off valves complete with plumbing - $130 PRICE DROP $100
35. gtr calipers front & rear, epoxy coated high temp red with a painted high temp stencil 'nismo' - $350 PRICE DROP $300
36. 'race brakes' race compound pads front & rear - $180
37. passenger side window switch - $40 PRICE DROP $30
38. genuine black gtr bootlid badge - $70
39. full set of front & rear gtr seat belts in good condition - $100 PRICE DROP $70
40. os giken triple plate clutch - $1700 PRICE DROP $1650
  • Replies 386
Plastic fuel cap I have.
Are u referring to the boot release cable which runs from the drivers seat?
sorry for late reply, yes i am referring to the cable which runs from the drivers seat.
cheers
stock gtr blow off valves i take them and the brake booster reservior that sit in the right hand corner next to the booster include the hoses .
pm send
pm send
pm sent mark
sorry iplen - reason the pm's were not coming thru is because my inbox was full, ive made more room though so pm's will no longer bounce
another update of the list of remaining parts with revised pricing :)
1. gearbox - PRICE DROP $650
2. front door trims - PRICE DROP $180
3. rear door trims - PRICE DROP $120
4. dash cluster with 180km/h speedo (showing 73000km) - PRICE DROP $110
5. doors (includes tinted glass & power window mechanisms) - PRICE DROP $270
6. front windscreen (with antenna) - PRICE DROP $100
7. rear tail lights - PRICE DROP $110
9. blitz icolor dual solenoid dsbc boost controller (with user manual) - PRICE DROP $550
10.attesa 4wd pump - PRICE DROP $250
11.hicas pump - PRICE DROP $80
12.spare wheel - PRICE DROP $30
13.dash vent (passenger side) - $50
14.left cv with knuckle assembly - PRICE DROP $100
15.right cv with knuckle assembly - PRICE DROP $100
16.drivers side window/mirror control - PRICE DROP $60
17.sun visors - PRICE DROP $20
18.complete boot trim - PRICE DROP $100
19.instrument panel surround (does not have headlight switch & wiper button) - $30
20.power steering line - PRICE DROP $20
21.caster (radius) rods (bushes are good) - PRICE DROP $50
22.radiator overflow bottle - PRICE DROP $15
23.passenger & drivers side door sill garnish - PRICE DROP $50
24.door seal finish - PRICE DROP $10
25.factory side skirts (black) - PRICE DROP $160
26.front subframe - PRICE DROP $40
27.bootlid rubber seal (no tears) - PRICE DROP $20
28.power steering reservoir - PRICE DROP $10
29.earls braided brake lines (front and rear) - PRICE DROP $80
30.gtr calipers front & rear, epoxy coated high temp red with a painted high temp stencil 'nismo' - PRICE DROP $250
31.'race brakes' race compound pads front & rear - $180
32.passenger side window switch - PRICE DROP $20
33.genuine black gtr bootlid badge - PRICE DROP $50
34.front gtr seat belts - PRICE DROP $50
35.os giken triple plate clutch - PRICE DROP $1550
Please note that the above after market parts have done no more than 2000km & if there is any damage on any of the parts I would have most certainly mentioned it next to the item...in other words, all listed parts are in very good working order & generally unmarked.
    • I am getting the same issue. Did you resolve it? I just got it after installing my new super coppermix and literally the same issue, new fork, new 18mm carrier, release bearing that came with the kit and replicated the exact same sound.
    • If you like - I have the STL files so I can email em. There's a couple of gotchas (i.e the holes are not threaded so you might need/will need) to utilize some M3 melt-in threads for some of the points. However if you want to be super accurate, and are willing to remove your calipers and your SHOCKS it's a really good tool. You also might need to scale the part that measures the tyre width a bit wider. It defaults to a 7.5in tyre and I mean who is running that. Luckily with the magic of CAD this is very easy to rescale.
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
