here is another updated list of parts left - i still have more to add :)
please note reduced pricing as hightlighted in red!
1. gearbox - $750 PRICE DROP $700
2. front door trims - $200
3. rear door trims - $170 PRICE DROP $150
4. dash cluster with 180km/h speedo (showing 73000km) - $150 PRICE DROP $130
5. doors (includes tinted glass & power window mechanisms) - $320 PRICE DROP $300
6. front windscreen (with antenna) - $150 PRICE DROP $130
7. rear tail lights - $160 PRICE DROP $130
8. factory afm - $50
9. blitz icolor dual solenoid dsbc boost controller (with user manual) - $600 PRICE DROP $570
10. attesa 4wd pump - $350 PRICE DROP $300
11. input shaft for transfer case/4wd - $50
12. work wheel nuts - $120 PRICE DROP $100
13. hicas pump - $120 PRICE DROP $100
14. ohlins suspension, very nice ride & not too hard/bumpy like most coilovers - $400 PRICE DROP $350
15. rear subframe 'pineapples' to lock in blown out bushes & stiffen rear end - $70 PRICE DROP $50
16. spare wheel - $50 PRICE DROP $40
17. dash vent (passenger side) - $50
18. left cv with knuckle assembly - $150 PRICE DROP $120
19. right cv with knuckle assembly - $150 PRICE DROP $120
20. drivers side window/mirror control - $80 PRICE DROP $70
21. sun visors - $30
22. complete boot trim - $160 PRICE DROP $120
23. instrument panel surround (does not have headlight switch & wiper button) - $40 PRICE DROP $30
24. power steering line - $40 PRICE DROP $30
25. caster (radius) rods (bushes are good) - $80 PRICE DROP $60
26. radiator overflow bottle - $30 PRICE DROP $20
27. passenger & drivers side door sill garnish - $80 PRICE DROP $60
28. door seal finish - $30 PRICE DROP $20
29. factory side skirts (black) - $180
30. front subframe - $60 PRICE DROP $50
31. bootlid rubber seal (no tears) - $30 PRICE DROP $20
32. power steering reservoir - $20 PRICE DROP $10
33. earls braided brake lines (front and rear) - $120 PRICE DROP $100
34. factory blow off valves complete with plumbing - $130 PRICE DROP $100
35. gtr calipers front & rear, epoxy coated high temp red with a painted high temp stencil 'nismo' - $350 PRICE DROP $300
36. 'race brakes' race compound pads front & rear - $180
37. passenger side window switch - $40 PRICE DROP $30
38. genuine black gtr bootlid badge - $70
39. full set of front & rear gtr seat belts in good condition - $100 PRICE DROP $70
40. os giken triple plate clutch - $1700 PRICE DROP $1650
  • Replies 386
Plastic fuel cap I have.
Are u referring to the boot release cable which runs from the drivers seat?
sorry for late reply, yes i am referring to the cable which runs from the drivers seat.
cheers
stock gtr blow off valves i take them and the brake booster reservior that sit in the right hand corner next to the booster include the hoses .
pm send
pm send
pm sent mark
sorry iplen - reason the pm's were not coming thru is because my inbox was full, ive made more room though so pm's will no longer bounce
another update of the list of remaining parts with revised pricing :)
1. gearbox - PRICE DROP $650
2. front door trims - PRICE DROP $180
3. rear door trims - PRICE DROP $120
4. dash cluster with 180km/h speedo (showing 73000km) - PRICE DROP $110
5. doors (includes tinted glass & power window mechanisms) - PRICE DROP $270
6. front windscreen (with antenna) - PRICE DROP $100
7. rear tail lights - PRICE DROP $110
9. blitz icolor dual solenoid dsbc boost controller (with user manual) - PRICE DROP $550
10.attesa 4wd pump - PRICE DROP $250
11.hicas pump - PRICE DROP $80
12.spare wheel - PRICE DROP $30
13.dash vent (passenger side) - $50
14.left cv with knuckle assembly - PRICE DROP $100
15.right cv with knuckle assembly - PRICE DROP $100
16.drivers side window/mirror control - PRICE DROP $60
17.sun visors - PRICE DROP $20
18.complete boot trim - PRICE DROP $100
19.instrument panel surround (does not have headlight switch & wiper button) - $30
20.power steering line - PRICE DROP $20
21.caster (radius) rods (bushes are good) - PRICE DROP $50
22.radiator overflow bottle - PRICE DROP $15
23.passenger & drivers side door sill garnish - PRICE DROP $50
24.door seal finish - PRICE DROP $10
25.factory side skirts (black) - PRICE DROP $160
26.front subframe - PRICE DROP $40
27.bootlid rubber seal (no tears) - PRICE DROP $20
28.power steering reservoir - PRICE DROP $10
29.earls braided brake lines (front and rear) - PRICE DROP $80
30.gtr calipers front & rear, epoxy coated high temp red with a painted high temp stencil 'nismo' - PRICE DROP $250
31.'race brakes' race compound pads front & rear - $180
32.passenger side window switch - PRICE DROP $20
33.genuine black gtr bootlid badge - PRICE DROP $50
34.front gtr seat belts - PRICE DROP $50
35.os giken triple plate clutch - PRICE DROP $1550
Please note that the above after market parts have done no more than 2000km & if there is any damage on any of the parts I would have most certainly mentioned it next to the item...in other words, all listed parts are in very good working order & generally unmarked.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
