For sale standard R33 Gtr parts, were all working fine prior to upgrade.
Turbos - $300
Dump pipes - $50
Front pipes - $50
Fuel pump - $60
Injectors - $300
Castor rod bushes - $40
Cam gears - $40
Computer - $60
Air flow meters - $300 - Have been repaired, were working perfectly
Parts are located in Sydney - St George area
https://www.sau.com.au/forums/topic/360399-r33-gtr-parts/
UPDATE
For sale standard R33 GTR parts, were all working fine prior to upgrade.
Turbos - $300
Dump pipes - $50
Front pipes - $50
Fuel pump - $60 - SOLD Pending Payment
Injectors - $300
Cam gears - $40
Computer - $60
Cusco Catch Can - $150 - ON HOLD Pending Payment
https://www.sau.com.au/forums/topic/360399-r33-gtr-parts/#findComment-5760172
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
