Where abouts are you located Im not really looking to sell mine but I may be swayed if the right offer came around it's totally stock apart from the full turbo back exhaust and coilovers. And genuine GTR body kit. Only done 117000kms and had new clutch timing belt and water pump done in the last 4 months
https://www.sau.com.au/forums/topic/360424-wtb-r32-skyline/#findComment-5754341
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
