Beat ya to it :D
Dashboard Fusebox
Left Column, top to bottom: Right Column, top to bottom
10A – Rear Wiper 10A – Shift lock
10A – Anti-stop 10A – A/T control
10A – Starter Indicator 10A – Air conditioner
10A – Room lamp 10A – Engine control
10A – Stop lamp 10A – Air bag
10A – Electrics 20A – Blower motor
10A – Engine Control 20A – Blower motor
10A – Hazard lamp 10A – Audio
15A – Fog lamp 15A – Cigarette lighter
10A – Turn signal 20A – Front wiper
10A – Meters 10A – Mirror de-fogger
10A – Electrics 20A – Rear de-fogger
Note that the engine bay fuse / relay box has a fuse key printed on the inside of the cover in english.
Download this
http://members.iinet.net.au/~robi/skylinebook.pdf and print it out... it will help you out heaps :)
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
