Pretty much as above, i have an 96 r33 gtst with a recently NTK OZA395-E2 wideband oxygen sensor however when i hook it up to my laptop and use Camsult or ScanTech software i can only view the O2 sensor Voltage, is there a way to convert this into a readable AF ratio? do i need another program?
That is not wideband, that is narrowband sensor. Narrowband are as the name suggests, narrow. 0.45-0.55v is stoich AFR of 14.7, any other reading like 0.55 to 1.0 volts is richer than this, and 0 to 0.45 volts is leaner than this. It cannot be converted to a useable AFR reading.
Cheapest would probably be to import the AEM UEGO wideband kit from the US, probably looking at $200-250 delivered.. or if you're willing to DIY then maybe: http://wbo2.com/
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
