Hey guys, thanks for coming down to the khana. was great to see you there.
How would you feel about a cruise to the bunyas one weekend.
I'm sure I could put a crew together and we could head up the hill to hook up with the gang and go do lunch on the mountain.
Thoughts?
Thoughts?
Sounds like a good idea Noel
Next cruise dates at this stage are
15th of April- Nice Sunday cruise to a local pub for lunch.
19th of July- It's a THURSDAY, Cruise down to QR to watch the Nissan (time attack) day
What time are you looking at doing the cruise on the 15th of April? We have happy laps in the morning, might try make it up to Toowoomba for lunch with you guys.
Probably be a 11am meet up and leave at around 11:30
I should be able to make that. Would be done with Happy laps by 9am at the latest giving me two hours to get up there. I'll see who else is keen to come along.
Can always make meet up time a bit later. Couple of us Toowoomba guys are thinking about cruising down to Kingston Park for a bit of karting one weekend. Should see if any of you Brisbane guys are keen
Tires cleaned of most to all rubber they picked up from the motorkhana from last weekend. Gearbox oil and diff oil levels checked, cd player working again and connections for trickle charger fitted.
Ahh so on here is where it's at hey? :O
I'm down with whatever you guys are doing and where ever you're going ;) Yeh there're some gravel roads at the Bunyas that we'll have to make sure we don't get sidewayz on...but never know, that was years ago and they may be surfaced by now.
And yes, as for the Kingston karting - we could fill a whole group if we have peeps from T-bar and Brizzy coming along!
Thoughts?
Yeh thanks for letting us hop on for a lap of the course! Turns out that my rear coil over is now totally and utterly shagged so will have to get new ones E-SAP. She feels quite wobbly now in left hand corners :/
Bout time you poked your head back in here Tom. Last time I was at the bunya's, the way we went was all surfaced, well from what I can remember anyways.
When do we want to do that karting trip? May or June?
Haha I'm sorry I sorry :P Last time I was on here this thread was only a couple posts long!
Well I'm pretty easy - we don't have anything happening it either of those two months? Suppose we try May and see how available everyone is?
must be getting closer to drinkies again amirite?
Saturday Night? BBQ and drinks at mine? Maybe even a game of poker. My self imposed drinking banned ended on the 15th. Bad day at work and one of the guy's from work birthday= me needing a drink
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
