... and then have the old man strangle me homer simpson style. (and I'm not taking on dad, he's huge lol)
I'll take him on thumbsup.gif.
People still keen to do a kingston park cruise?
Dropped the mrs home just before, not gonna lie - the TCS was flicked to off
Other than that it's perfect SWTOR/Skyrim weather :banana:
Or perfect weather to sit at the southern and get drunk for one of the guys from work birthday. If I wasn't going to the pub I would be sitting in the racing simulator playing GT5 all day
How was JDMland? Also where is my 34 GTR or KPGC110? I hope it's on the boat on the way over to me thumbsup.gif
Keen for the cruise Nick? Completely forgot to send you a text about it.
Yep 180 Nick.
Also how good is this weather?
Anyone keen for a photoshoot next month?
Just got back from Japland 2 days ago.
Nikk:
Yes...its me! Massive SAU fanboy/troll but proud non-skyline owner :D
Chris:
Couldn't get your cars for you, Chris. BUT I saw some pretty cheap ones for sale over there...couple hundred k's north of Tokyo with 'special' glow in the dark paint. Dealer guarantees me the paint will stay that way for at least the life of the car and then some :P
In all seriousness, I managed to see heaps of decent vehicles there...still plenty around but they only show up at night mostly.
I got some pretty pictures too...although most cars escaped the camera lens (mostly headed in the opposite direction, too quick for me to get the camera out)
If I show you some pictures of said cars you requested, will that suffice?
You guys just keep posting up details of cruises on here or text me, please. Might not make it for all but will definitely try haha
Nikk:
Chris:
Defo keen on the glow in dark paint one, only if it's glow in the dark green thumbsup.gif
I guess pictures will have to do. Good to hear there are still some good ones getting around over there.
Only details about our cruises I will be post up on here from now on will be the date and whether it's a pub cruise or going to a sau event, all final details will be kept on the down low, as per request of a couple of the locals
Hey guys,
Just wondering if any of you have heard of the Oakey or Pitsworth races? Has anyone on here competed in them or know the routes they take?
Cheers
Are you talking about the sprints? Have never been was going to go last year but had other things on the same weekend but planning on having a look of I have time this year. Some of the guys from work went to both last year and said it was really good. Here is a map of the Pitsworth sprint course http://www.pittsworthsprints.com/course.htm
I used to head out an camp at the leyburn sprints heaps in school and after. One of my mates brothers had an old XY he used to flog around the course - and he was no expert. I'm sure you could give it a crack however they are 'historical' sprints so not sure what the categories are for cars.
Maybe we should cruise out as a club for a peep on Sunday? Being the last day everyone goes a lot harder.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
