How I've never spotted this thread before escapes me.
White 33 black bonnet (lol) red front bumper (double lol)
Keen on cruises/meets in the future.
But welcome anyway. Always good to find another local skyline/nissan owner. Cruise to Brisbane on the 25th to meet up with some other SAU members. Then a local cruise to a pub for a feed on the 14th of april.
Will attempt to make it to the cruise to brisbane work stuff permitting.
Should be able to make it to the april meet also.
There is definantly a lot of skylines in town would be good to see the community grow. :)
Shucks, if I come along, I'll just sit in my little corner then hey while you guys all talk RB and stuff...
Hahaha If you have a nissan I'm sure I could think of things to talk with you about, I've got a s13 as well.
Well we cannot spend the whole time talking SR's now can we nyaanyaa.gif Where are your Japan pics? I wanna see pics of the glow in the dark cars teehee.gif
LOLOL Said cars were north of Tokyo. I was actually in Osaka...much much further south :P
I got the Japan pics here but perhaps this is the wrong place to post them up.
Chris - Perhaps the next time you have something going on at your place, I'll bring the pics in a USB for all to see ;)
And it has a couple pics of the cars you originally requested
Random question guys, what can i do to improve my fuel economy other than cleaning out the AFM and replacing the O2 sensor?
I do a round trip of 160 k's per day and am only getting 300 k's from a tank :/
Edited by A Grave Digger
A lighter right foot lol. AFM and O2 is a good start. Is it a stock ECU?
leaking fuel tank? busted fuel lines?
Repco will be having cheap electrical contact cleaner starting tomorow. Use that to clean the AFM contacts and filament. Leaves no residue.
O2 sensor a "bit" more expensive LOL...but you'll make up for the cost in fuel savings alone after a couple weeks with that sorta consumption.
Kudos motorsport on here will be a good start to look for one unless someone can recommend another place.
Apart from that, you'll just have to live with the RB consumption. Almost every skyline I've seen leaves a big cloud of black smoke upon changing gears.
Perhaps a shift to the 'light' side (pun intended) would be in order.
2 less cylinders, cheaper rego and 650+km/tank fuel economy for me :P
sonnyQ- yeah mate from Toowoomba to Ipswich every day.
me_larr- I havent noticed any fuel leaking from anywhere but ill have a thorough check this weekend. Ill give the contacts a hit this weekend as well.
This is with a light foot guys :/ if I drive it hard ill go through a tank in a return journey. Got an O2 sensor from Vulture Motorsport on here, just waiting for it to rock up.
Don't forget the filament inside the AFM.
You'll need to remove it from the intake and physically spray the heating filament/element of the AFM until its clean of all oil/dirt/dust.
Cleaning this will be more important than just the contacts on the plug.
Should your AFM have no mesh on the ends (unlikely), try not to physically touch the filament bit.
I gots a strange feeling your economy will jump 100ks or more with just AFM cleaning and new O2 :)
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
