Details for Sunday please :)
Not sure as of yet but would like to know anyways.
Wife says as long as we don't get up to anything stupid, I should be OK to go if nothing comes up..... :unsure:
Just going for a little drive and then go somewhere for lunch nothing too crazy. That's if the weather is good
Boo to everyone getting to do fun car stuff this weekend. Car is still not back together. Real sorry I won't be able to make it up to meet you guys for lunch and a cruise.
Its all good BOZ another time
^ 7.30am.............
Chris, don't you sleep (in)? :wacko:
What the hell is a sleep in. Between getting up at 6 every morning for work and the neighbors chickens going off there heads this morning at 6:15 I don't get to sleep in. If my ankle wasn't so sore I would of jumped the fence and ended up eating chicken for lunch lol
Hey sounds good...how much does it cost? I'm keen to let loose ;)
lol at my quoting fail :P
Haha! I saw that and thought WTF? didn't make sense. lol
If you're a paid member of the club is $80, $110 for non paid members. Cheaper that a driving fine!
So this is happening tomorrow? I take it you just rock up with helmet etc...and you don't need the aasa for it?
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
