There is myself, tom, clint, natro nick and 180 nick. There are about another 10 that I know of but don't want to do meet ups
& 180 Nick isn't allowed to come for this one cos he's not a skyline owner, right?
Just so you know:
My brakes and hubs are off a skyline.
My vehicle security was done by one of your own.
The father in law used to drive a Hakosuka.
Do these count?
What if I rock a GT-R badge on the front and back? :D
Bah, I'll be working anyway :P
Spewing I can't even tag along with someone...
Post up lots of pics in here or somewhere on the SAU mother forum, please. That's all I ask.
You can bring a 180 if you want...we let Tony come in his Maxima :P Only event we run that is vehicle specific if the Charity Cruise. I would rather an SR powered 180 (or even *shudder* a CA powered one) over a 33 with an LS1.
  • Like 1
Nick ditch work and bring the 180 :yes:
Just so you know:
Do these count?
Buy a dodgy bread roll from Nicks bakery. Get the sh1ts. Bail on work because Straylan Day!
Sorry guys, I really couldn't ditch work. Made a promise.
Now if I had made a promise to turn up for the cruise, I would have, by hook or by crook. :)
Where's my pictures, ppls???
How many turned up? (especially the tbar crew LOL)
What sort of cars?
Did everybody get to do a blanchview? (downhill touge ftw)
That was a good cruise ;) And the feed was quite the nom noms too! Too bad most of the cruise was spent at red traffic lights tho :P
For sure gd to finally meet everyone. I ended up going to esk, btw what should my oil temp be hovering around ? It was almost on 150 degrees that bad ha?
Yeh it sure was - as always, we need more cruises ;)
Um oil temps for most cars should be around 80-100 degrees - that's what the oil is designed for.
Yeh that sounds a bit excessive there Brian, especially seeing that your engine temp is meant to be around 80-85deg (basically the same as what the oil is designed for)
You may have to check all your cooling systems...
Thanks mate. Argh more money ha so annoying
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
