Oh they'd hold up alright with his driving style....you really have to keep that thing above 6-7k for a while and around long corners and shit to start starving the bearings. Oh, and a dyno at a certain workshop that will not be mentioned will also do it :D
Just run an extra L of oil for track days ;)
Blanchview is free, Nick :P
Non-members still pay a fair bit. I'm not poor but I have reasons to be saving as much as I can at this point in time so I'll have to pass on Happy Laps until things settle down a little on my end.
Moreover, am looking forward to catching up with everybody and any new members that show up :)
BTW, why does everybody think Chris drives his car slow? My reputation is unmatched 'round these parts.
Yeh they do cost a fair bit these days! It's more for the social side of things than anything...kinda forgot that they put it up by like $20 =/ Used to be $30 for non-members grrr
Yeh well I'm an unemployed bum too haha...but I reckon I might end up going yet.
Haha, well, you reckon I drive slow....you should see Chris. I almost stall out when driving off at the lights behind him ;) jk
What's with all the picking on me as to how I drive my car? I drive my car with the respect it deserves. I on the odd occasion give the old girl a squirt and maybe take the revs past 4k. I know I baby the car but if any of you owned it would yous drive it any differently to the way I do?
Anyone is welcome with any car. Except Nick and the General lee ;)
Although hell be there come hell or high water. :/
I wasn't giving you sh1t? I'd do the exact same. It's quite refreshing to see one being preserved. :)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
