Hey David,
Welcome to the group! What sort of engine are you chasing?
Would be great to see another Skyline in the mix.
Cheers,
Tony
Hey mate, is that kerrys old car?
yeah it is did a swap for it but it overheated on the range tremostate got stuck and ratator cracked now blowing heaps of smoke need just a temp motor to get me out of shit while i rebuild this one
Not good man, I haven't seen that car since charity cruise 2011
yeah was hoping to get out and meet some people havent had a skyline for few years now really didnt need this one breaking down but thats life
FYP brah. But if you drive your car as little as I do, you don't really have a problem with things breaking a lot haha.
Yer, mine was fairly healthy before I did happy laps now I have a few things to fix...
I was sexting Tom last night and I couldn't work out why he kept saying my car felt laggy when he was in it.... Then i reminded him that all the runs he had in it were taking off in second gear, god damn South Africans, they don't listen lol
So the car can't accelerate at low speeds - useless on the street and strip
So the car can't turn - useless on the track
What's the point of this thing again? And you point fingers at the Maxima! Lol
Only ATM, as soon as the gearbox is sorted its all kinds of smokeshow. Highway pulls from 100 is fine....
Why can't the car turn? It has brand new coilovers and camer arms... Only couldn't on the weekend as the battery would fall out lol
Just realize that I have only done less the 10kms in the 32 since the toowoomba cruise. And haven't even done 300kms all year
The moral of this story is you need to buy a gtst and come fang it with the brosephs
That are 25's popping up occasionally. Check out ebay
been looking around but short on coin at moment and ute is broken at moment so yeah sucks to be me just ordered rebuild kit for this mottor figured i had a bit more time before i had to worry about it
im selling my tv so that should help anyone want a 60 led sharp only couple months old i paid 2700 for it will take 1200 bucks
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
