  you get off on telling people this
Haha
All it means to me is SEVERE engine wear every time the bone dry oil starved motor is fired up =/ You're killing it Chris :( You should turn her over every 3-5 days so that she's never totally dried out..
Haha
She gets started one a week Tom
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
