Haha love the whole danger to manifold thing....bloody last thing to be concerned about imo :D
Yeh that area is pretty nice Clint, I went halfway along somerset a while ago but had to turn back because of juice levels haha
Because manifolds are cheap?
lol no because it's like the strongest part of the whole damn setup provided it's not some cheap chinese p.o.s knockoff with poor welds / no braces :/
Nitrous backfires have been known to explode the composite LS inlets....
Mmm think they only really beefed them up a bit in the 94's yeh? But then and again it's probably not even that bad....I reckon it's the same load of crap as all that ceramic turbo paranoia and myth spreading. I bet that slightly thinner pump drive on the older 32 only failed on a handful of occasions just like the ceramic turbos under extreme conditions way outside of design envelope.
But in saying that I'd only ever want a late model one too...mainly because it's younger ;)
What's happening on Sunday? Was that the bbq/drinks?
Cruise and lunch this time. When the weather is warmer will do bbq and drinks
2nd month 93 I think is when they changed the oil pump setup
Nice, yeh I should be free for this
Chris is spot on. As well as getting the brakes the v spec also got the r33 crank. I have a 33 crank too. On the topic of exploding manifolds, anyone remember when Rhys McGreggor did it on the heat treatments GTR at jambo? Put a huge reverse don't in the bonnet.
I saw a photo of that, white 32?
That's the one!
Also can't beleive you guys use heiffer creek road as a play ground. Last time I was there it was scary as f**k. It was a goat track with semis on the wrong side of the road every second corner. Must have fixed it up a bit since then.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
