Had / have two falcons
Xr8 and the xr6t
Was hanging around with a bunch of boys from the SA xr and fpv club . One dude had an xr6 t daily and a r32 gtr ( now a full racecar) got talking and was talking about shoe horning an rb neo into an r32.( forumember reading up )
Then I was workkng in sydney for 3 months and started looking at 32 gtrs not at all seriously ......... then somehow impulse bought a 33 gtr :-p
Um well its a bit different and obviously an older car and AWD ( no correcting angles with your right foot ;) )
Bit concerned about safety at this point. First thing I did was got it on a dyno and did oil and flush . coolant fuel filter etc
punched out 252 awkw @15psi ....while misfiring......... then put in Splitfires and a slightly cooler plug and shes all good. a=
major concerns at this point are slight underbody rust, and turbos....ceramic nervousness. given the boost level. Uni group seemed happy with it and its condition.
Once I get my gear up here and get some new tools going to do diffs, transfer and gearbox.
I think the clutch is slipping so that's on the cards at some point.
So in short. I am loving it, but I have some concerns and have had to fork out a bit of cash on it much to the missus disapproval. but the way I look at it is, it's a (long term) project. and I want it clean rather than modded first ( hopefully. though we know how mod bugs are).
Did i read that right ???? R33 LS1.......?????? Right boys fetch the holy water ( old engine oil from a PGC-10 mixed with R35 GTR brake dust) we have an exorcism to perform
Edited by ibrox90
I didn't go but I ran into the abom on the way to Brisbane :P
Sounded hot. Would have loved to have taken it on in the Caldina for a couple hundred metres to see if it goes as good as it sounds.
Nick's lucky we met on the Warrego :ph34r: :ph34r:
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
