Oh yeh it's pretty good gear ;-) I just mean for your car Clint...you only want to run an extra 2-3 pounds yeh? That might be an extra 20 odd horses or so - hardly worth the expense of a Nistune because the stock ecu will happily dump a bit of extra fuel in for ya..
They *where* brand new ;)
Why the stall man? Can't you just put a manual in? ;-)
If you put a manual in I'd seriously conscider making you an offer haha
Don't want to be a dirty cog swapping Neanderthal lol
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
