Maybe we need to distract Nick when Chris Rogers is around next and see what happens
Nick skitzes out and yells at mr Chris to gtfo of my car... Very short tempered if anyone touches/damages my car or my guitars
You don't mess with a mans car
So we can fill the abomination with your gee-tars and then burn it all?
LOL, you've spent so much of your hard earned on this car, spending a fraction of that to make it GTA proof should be your utmost priority at this point in time.
Apart from brakes, diff, a proper gearbox and an RB :ph34r:
And a lot of high proof alcohol to burn it.
Hey I have a turbo LSD diff in there and this gearbox has over 3 grand dumped into it and shifts like hulk hogan kicking you in the nuts :P
i kinda think it sucks too. i don't like how spastic the driving is, nor do i like not being a black gangster. i bought san andreas the other day on PSN but i am yet to download it because it takes 10 years because my internet blows..
Edited by Seano350GT
Gatton Clifton road......hey Clint? ;)
What up heffer creek?
What u mob doing on my proving ground lol (gotta watch for trucks up in dem der hill blins kroners make derm sity folk stoppa there breefin n whartknot)
Lol I've been told it's a very scenic route through there with gorges and bridges and all sorts of pretty stuff :P
I wouldn't mind going along it?
It is a nice drive just yer wild life and trucks cutting corners are an issue
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
