Hi Guys,
I've got my R33 GTST turbo, exhaust and computer for sale due to upgrades. It has been making 300kw for about the last 3 years and is still on the vehicle so happy to take take potential buyers for a drive. I plan to remove parts in about 1 months time when the new set up is ready, but willing to remove them earlier if sold prior to new set up arriving.
Can package and post at buyers expense, though prefer pick up on exhaust, located in Shepparton- North East Vic.
Please PM or call me on 0437 688 773.
TURBO -
R33 Hi flow turbo with OP6 rear housing.
HKS 14 psi wastegate actuator
Will bolt up to standard oil and water lines, dump pipe and intake.
The turbo was originally built by ATS in Adelaide with special exhaust and compressor wheels, not the normal hi flow wheels.
The OP6 housing was machined and fitted by Kyp at ATP in June last year and the turbo was checked over at that stage.
Turbo makes full boost by 3200-3400 RPM and is capable of 20+ Psi.
$1500
EXHAUST
3 inch CES racing split dump pipe with 2 O2 sensor ports.
3 inch gutted cat.
85mm cat back system with centre muffler and rear cannon with a 5 inch tip.
$500
COMPUTER
Wolf Version 4+ wire in
This computer is the 4+ so it has extra ignition drivers, compared to the plug in unit.
The computer comes with 30cm of loom, hand controller, instruction manual, ECU to laptop cable and software to be able to plug in and tune on your laptop.
Being a wire in unit it will suit all makes and models of vehicles, not just skylines.
$1000
Will sell Turbo, Exhaust and ECU as a complete upgrade for $2500
R34 GTR WHEEL CENTRE CAPS
Original paint in average condition.
$50
N1 GTR MAIN BEARINGS
Main engine bearings to suit R33 GTR (possibly all RB engines)BRAND NEW - Only have marks where we measured them up
Genuine Nissan parts
6x Main bearing sets
1x Thrust bearing set
These were purchased to fit my engine but we found that they were the wrong size for my engine.
If you refer to the Nissan workshop manual there are different sizes available, these are the black ones
$20
hey mate,
what else you got on the car for 300kw and the boost level you are running?
will the computer fit on auto?
how much does it cost to tune?
hey mate,what else you got on the car for 300kw and the boost level you are running?will the computer fit on auto?how much does it cost to tune?
The boost was set to 21psi for 300Kw, the car has usualy suporting mods, intercooler, GReddy plemun, 850cc injector, cam gears.
The ECU will not run an auto trans but it could be used as a piggy back to the std ecu with the wolf controling the engine and the standard ecu controling the auto.
Im guessing it would be around $500 to tune, maybe a bit more the first time to set up all the calbrations for the sensors. Best to ring a tuner/workshop to find out
does the wolf come with a hand controller??
Yes the Wolf ECU comes with the hand controler
  • 1 month later...
  • 3 weeks later...
Hi Guys, Just an update price drop, all are negotiable. PM NUTR33 or myself if interested.
TURBO: $1200 ONO
WOLF ECU - $900 ONO
GTR Centrecaps - $40
Exhaust - only dump pipe and cat still available $250
N1 GTR main bearings - make an offer
  • 4 weeks later...
The Wolf ECU is a good all round ECU.
It has extra features over a power fc as it has programable outputs.
Thermo fans or anything else that you want to turn on or off can be set by any of the inputs, ie by revs, temp, boost.
You can run a wide band oxygen sensor with a display on the hand controler to check your tune while driving.
Im upgrading to the new Wolf ECU as i want some of the more advanced functions like launch control and anti-lag.
Cheers
Luke
  • 3 weeks later...
  • 2 months later...
WOLF ECU - $600 ONO
Exhaust - $350
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
