i just finished refreshing my rb25 last week.
new oil pan, new oil pickup, rb25 neo water pump, rb26 oil pump, new belt and tentioner, new head gasket and arp head studs. ran perfect up until yesterday. i was on the highway and i went to neutral to pull into a store and my oil pressure dropped to almost nothing. i pulled in an shut it off. started back up and hear lifters clattering.
oil pressure is about 5psi idling and at 2500 rpm its about 20psi. (using mechanical oil press gauge)
wtf could have happened. if i installed something wrong it should have been evident from the first start up, not 5 days later. nothing is leaking from anywhere.
also i pulled off the oil filter and the oil that came out was incredibly dark and had swirls in it which im guessing are my bearings, despite the oil being brand new.
any comments/advice are appreciated. thanks
https://www.sau.com.au/forums/topic/361293-rb25-lost-oil-pressurenew-26-pump/
i replaced the seal, torqued it to spec, i also used locktite on the bolts.
the oil is crystal clear on the dipstick, but the oil that came out of the filer was really dark and the swirls were a lighter grey, i was looking at it under a flashlight and the swirls were metallic.
its hard to explain. the oil that came out of the filter looked like it hadnt been change in a while, but its brand new oil.
well the motors out, pan is off.
Every rod is loose and every crank journal has a groove for the feed hole.
Oil pump screws were tight as hell....tried to get them off and 3 stripped out.
Oil pickup is tight and was completely clean where it sealed.
Everything is completely fcked and I still have no clue as to what happened.
FML
  • 1 month later...
there was nothing that stood out to lmk what happened.
the rod caps were tight, but the rods could jiggle.
and to make everything worse, i got another longblock, put another BRAND NEW rb26 oil pump on, and it did the EXACT SAME THING after about 500miles.
oil pressure gradually got lower and lower, but in the first week, i would easily hit 90+psi of oil pressure.
i saw that Blue32 had the same problem happen to his motor around the same time it happened to me. is there a chance of a bad batch of oil pumps?
i am completely clueless as to what happened. i have another longblock coming soon because this second one was under warranty. id like to figure out whats causing this so it doesnt happen again.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
