Hey, name's Essa (Zeus) ... Just recently bought a, used, gtr r34... first car bought using my own money cool.gif
was searching google.gif trying to find upgrades and some tutorials and came across this site. love the site, use it to read up on stuff while bored in lectures (attending Flinders, Adelaide) =P
https://www.sau.com.au/forums/topic/361381-hiya/
hmm, I'm a newb.
since gtr's are twin turbos then mine would be a none twin turbo r34 :P lol i dont know the guy's ad said it was an r34 :P no wonder it was cheap.
anyway, I still have a lot to learn from this forum and about skylines...
https://www.sau.com.au/forums/topic/361381-hiya/#findComment-5768517
Welcome. Both GTR and GTT are R34... Its kinda like any other manufacturers, you've got the BMW 3 series but the 3 series' broken down into a few other variants (e.g. 318 and 335).
Even though to the untrained eyes the GTT and GTR might look the same but they're not. Both internally and externally. It'll take you a little while to be able to tell the difference between all GTRs and GTT/GTST.
I hope you're not ripped off thinking its a GTR.
https://www.sau.com.au/forums/topic/361381-hiya/#findComment-5768605
I bought this car because it was a skyline ;p Nothing more nothing less, the reason I said a "GTR" because it had the emblem ... I don't have much info about them, as I said "newb".
Thanks for clearing that up... So what would a non turbo be called? GT r34? Because mine certainly doesn't have a turbo and the guy definatley said it was an r34.
https://www.sau.com.au/forums/topic/361381-hiya/#findComment-5768720
Lol srsly, that makes sense since I couldn't find an r34 that looked like mine ;p
The guy must have typed it wrong then, r34. So would $5k be a rip off price for it? It had an odo reading of approx 155k when I bought it.
https://www.sau.com.au/forums/topic/361381-hiya/#findComment-5768837
Welcome.
Not a bad looking 33.
Things you should looking at doing to your skyline ASAP
  • Replace all fluids (engine oil, coolant, gearbox oil, diff oil etc)
  • Replace oil filter, fuel filter and air filter
  • replace spark plugs
  • Check for indications of 100000km service (i.e. timing belt has been replaced)
Replacment fluid types etc can be found in the general mainatence section or use the seach function and see where it takes you.
https://www.sau.com.au/forums/topic/361381-hiya/#findComment-5768977
Yup already did some of that. I don't trust previous owners unless a logbook is shown. Which this car didn't have. Did the full fluid replacement and replaced timing belt. But still need to do the filter replacements and spark plugs.
Will fix those sometime this week :)
https://www.sau.com.au/forums/topic/361381-hiya/#findComment-5769045
    • No, so what happened is. I put a bunch of filler then I sanded it all down, I removed all the filler (unintentionally), then I put the epoxy primer on because that section of the panel is bare metal. The car is parked outside so I needed to protect it in the meantime incase it rains.
    • It’s definitely an import, the Aussie ones have reflectors in the rear bar, it’s also a turbo which none of the Aussie one were.    I remember back in the day I want a twin turbo z32 so bad and then I saw a 32 gtr and that was the end of that lol
    • Same can be said for Subarus motors ha ha!   I like the 300ZX, I nearly bought a Z32 before I bought my first Skyline. It was going to be a project. Then I found out there was a bit of a dodgy title with it... As in, someone attempted to commit insurance fraud with it and there was now some dodgy legalities around it. So at 18 I walked away from it.
    • The below is what the readings I had with the fuel pressure gauge which were correct. It seems like the issue is mainly during drive and not idle. I bought the new hanger hoping it could be the issue, perhaps I ruined something while cleaning, but I have not installed it yet since I have to wire up everything with the new plugs.
    • Actually, that's not entirely true. It's also the same motor in the 1st gen Nissan Cube but they're rare as hen's teeth.
