So, as this game is releasing in 15 mins according to GLaDOS@home.. who's got it preordered?
My guess is that this is going to be a serious contender for GOTY on any platform...
Also for anyone wanting a bit more backstory etc etc, Valve have released a really cool comic here on the official site: Official Portal 2 Website
Hurry up 10 minutes!! :)
https://www.sau.com.au/forums/topic/361452-portal-2/
I'm buggered... been sitting at the computer all day doing a uni programming assignment and straight after that raked in 5 hours straight of Portal 2 and my ass and leg is killing me :laugh: will finish it off tomorrow morning..... or maybe after a shower possibly :laugh:
https://www.sau.com.au/forums/topic/361452-portal-2/#findComment-5770225
any spoilers and i will personally murder everyone
i won't be able to play it for at least another week; internet gets turned on at my new place wednesday next week and still no room for a desk :(
So there's this gun right... and it shoots portals :P
https://www.sau.com.au/forums/topic/361452-portal-2/#findComment-5771178
There's stuff in the game code already for DLC maps. Good option is that they release a few free and a map making tool (though supposedly you can shoehorn the art assets into the map maker of some other source game and that it only crashes occasionally. bodge job though). Bad option would be of course paid maps... But at least i'm pretty sure that we're going to get something.
Edited by sneakey pete
https://www.sau.com.au/forums/topic/361452-portal-2/#findComment-5781185
yeah i'm playin on the 360.. so no steam hack for me.. highly doubt there will be some free maps.. they seem to be milking as much money as they can in games atm.. but either way.. as long as its worth it.. (not like COD map pack rip off)
https://www.sau.com.au/forums/topic/361452-portal-2/#findComment-5781331
For those interested. A comparison of various screenshots between the three platforms. Obviously PC smashes the consoles but still good to check out.
Something that does shit me though is how they use component connection for the ps3 screens thus not enabling superwhite and wide colour spectrum. That is actually because of HDCP - prevents HDMI capture.
http://au.gamespot.c...topslot;thumb;4
Hover over the selected platform for a couple of seconds to load it.
https://www.sau.com.au/forums/topic/361452-portal-2/#findComment-5783448
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
