hey all spent the last few nights after work putting a 1996 nissan skyline gtst engine and loom in my r32 gts everythings hooked up and working fine just a small lil problem it wont start ive read theres a grey wirer that is the power feed for injectors were is it or could it be something else? im not to familia with nissans but it sounded so easy when i decided to do it all lol any help would be wicked other wise im gona have to take it to a sparky.
regards marty
https://www.sau.com.au/forums/topic/361506-help-please/
regards marty
Marty, if it is a 1996 model then it will be a series 2 which has a single common power feed to the plugs and injectors. The series 1 have separate power feeds. Easiest way to tell is the series 2 only has one relay near the ECU whereas the series 1 has 2. The R32 loom receives the main power feeds from the plug near the power steering reservoir whereas the RB25 loom receives the main power feeds from plugs in the cabin near the ECU. I have previously posted a wiring guide for this conversion and although it is written around the series 1 it should give you a clearer idea of what needs to be done.
Cheers
https://www.sau.com.au/forums/topic/361506-help-please/#findComment-5773751
hey yes it is a series 2 rb25det i used the full r33 loom that was in the wrecked car i got it from started fine and drove sweet as now that its all been put into the r32 all the dash and heaters etc work after ive adapted the plugs car turns over just wont start. i used the full r33 loom and ecu from the r33 so the injector power feed shouldnt matter am i right? sorry im a little bit confused to whats goin on any help with something i might have missed or any body that has done this before thanks
https://www.sau.com.au/forums/topic/361506-help-please/#findComment-5774237
hey all thanks for the help have got it going now after looking at photos of a engine bay online found 2 plugs the same in the engine bay one was pluged in the other was not swaped them over and started first pop. has any body out there put 19 x 8.5 on the front and 19 x 9.5 on the bak of a r32 i have got a guard roller so that will help a bit just cant find any pics online any were biggest ive seen are 18s
thanks
https://www.sau.com.au/forums/topic/361506-help-please/#findComment-5775324
ok they might
i have 17x9-255's +55 on the rear and the inner face of the rim just clear's the rear tie rods by like only 1 mm
so your rims are 1/2 inch wider but have 15 mm less offset than mine, if they do they will b heaps close
i will post a pic tomoz if u wanna see how close they are.
https://www.sau.com.au/forums/topic/361506-help-please/#findComment-5777104
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
