Hi folks,
As thread title, I'm looking for R33 GTR front bumper (Without N1 Vents is most desirable), I'd like it to be complete (lip, indicators, undertray, splash guard, brake ducts etc), it have to be in Midnight Purple - LP2.
And may look into getting Bonnet in same colour without N1 lip (Can swap if desired).
I'm located East suburbs of Melbourne.
I can be contacted by PM or text me on 0430 129 511.
Cheers
Grant
https://www.sau.com.au/forums/topic/361592-r33-gtr-front-bumper/
Hi all,
It's currently doing my head in.
I'm offering to swap my 400R front bar for complete standard front bumper, if you've got one in same colour and in same state, we should talk.
I'll put up a ad soon on F/S section with pictures.
Cheers
Grant
Hi all,
If you have one, please act like you're actually selling them.
Still chasing for one, traders are welcome to respond to this thread.
Cheers
Grant
  • 3 weeks later...
Hi, sorry, front bar is SOLD, will take photos of the bonnet.
I have standard front bar on mine but it has N1 vents if you're keen?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
