Hey guys and gals,
I have just purchased a 2008 370GT SP through Geoff at Prestige Motorsport (who has so far been extremely helpful and actually found me a better car, on paper, than I thought I would get for the money) and it should be on its way very soon. Does anyone have any advice as to what tyres I should go for, to get it past compliance?
Tyre sizes are: Front: 225/45R19
Rear: 245/40R19
The car is going to be a daily driver so i dont want anything over the top or that gives a harsher ride and dont want to spend a fortune, up to $1500 for the set, maximum. Does anyone know of a good spot to get them in Brisbane? The car will be complied in Brisbane and I am in WA so I want to make sure that the compliance place doesnt try to make any extra $$$ on the tyres.
On a different topic, I have been looking at some of the basic mods that people recommend and have read about the grounding kit that suuposedly improves throttle response etc. Does anyone have any experience with these and know if they actually make any difference?
Attached is the Auction Sheet for the car, from Japan.
Cheers
Al
https://www.sau.com.au/forums/topic/361903-tyre-recommendations-for-370gt/
hey mate not sure with tire sizes and all but just thought I'd add my 2c, I had stock 17" on v35 coupe and tires where Yokohama advan sports and they were very very good they had minimal noise and enormous grip and barely changed in wet conditions
Mate, I too just got a G37. And the dealer recommended that I source my tyres from the US.
Apparently the price difference plus postage is still MUCH cheaper than what you can get down here.
like these guys:
http://www.performan...ction/tireBrand
http://www.tirerack....=5&sortValue=22
http://www.1010tires...ry=Summer+Tires
+1 on the Advans. I'm running 255/20 front & 285/20 rear and the grip in all conditions is pretty hard to beat.
For a daily I would look at these:
http://www.yokohama.com.au/ourtyres/tyre.aspx?tyreid=64
Edited by mosoto
Do tyres from the US meet the Australian Standards criteria? this could cause issues for compliance.....
It would be f'ed up if they dont accept the Jap tyres that are on it but let you put other imported tyres on......but then again.....thats government for you....
my car came with the factory jdm spec potenzas, so guess it depends on the compliancer?
no need to get tyres from the states fellas, buying tyres isn't a big problem if you know what you're looking for
wouldn't buy tyres unless I can see them first anyway, just find a tyre shop you trust
I have the 19" sport stockies & wanted to stay within factory spec,
so I run a 235/40/19 on the front which will still give an accurate speedo reading
running 245/40/19 on the rears
you can run a wider tyre on these wheels if you want, just google search a tyre size calculator so you stay within spec
about mods I have a grounding kit, lowered springs,exhaust & eibach pro swaybars
grounding kit actually made the auto feel smoother to shift (useless if you buy a manual as the difference felt is in the auto gearchange response), small but noticable improvement to response
lowered springs were for getting rid of large front wheel gap, Pain in the ass for getting around sydney but not too bad if you angle your entry
swaybars are the best investment I made, improved the handling 100%
exhaust was just for the sound, not much of a performance improvement as the base level performance is good anyway
shied away from getting intakes etc as my car is a daily driver & don't want to go crazy, besides supposed to be saving up for other things
  • 3 weeks later...
Hey YoYo,
Where did you get your springs and sway bars from. I really really want.
I live in Sydney
Any help cheers :)
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
