So I am currently stripping my R33 Gtst down in preparation for a race build, and am interested in the best way to store the engine when it comes out of the car.
Ultimately it will be pulled down again to check the internals are holding up, but would hope not to cause it any problems in the process of storage.
Thanks in advance
https://www.sau.com.au/forums/topic/361985-best-way-to-store-an-engine/
The way I do it is drain all fluids when engine warm, pull it out and fill with running in oil or a cheap engine oil, put plastic bags over intake plenum and turbo dump pipes and coolant openings with elastic bands to keep them on. And every few months rotate engine by hand just to keep it all moving.
Scott
Wouldn't really need to fill with oil, just leave abit in and as said turn it by hand. Water
is what you want out as it will corrode from being stagnant for so long. No amount of corrosion inhibitors will stop that.
And as said above, fill all openings with clean clotch or cover with bags. Even after a
fair while of not running my old motor still turned nicely, still had a nice clean coat of oil visible parts. To make turning easier, remove plugs so the pressure can escape the cylinder.
You can use a high quality water soluble oil in the cooling system, the type used for lathes and milling machines as coolant. But you must flush it very well when you put it back together. I have used it for years in salt water cooled ski boat engines stored over the winter with no problems. It ain't cheap but it works. But depends how long you want to store it.
    • Sane enough. Remove the roof liner, because the acid will go everywhere.
    • Thanks guys, I really appreciate the help and experienced opinions.  I have spent a lot of my life working on boats so I'm pretty good with fibreglass. I'll take everybody's advice in here;  I'll cut a little more of the 2nd layer away as it's a bit crunchy rust and also it's sitting high now. Then I'll wire brush it all a bit to get off anything loose, then I'll soak the bejesus out of it all in rust converter. I'll make sure to get a little hose piece and feed it into all the holes and gaps between the roof layers. Then I'll fibreglass up the holes.  Then I'll get a pallet of filler and mix it with 3 buckets of hardener and hope that is enough to build up the roof corner.  Does that sound sane? Is one type of filler better than others for this?
    • My goals for it atm are to get it registered, respray and some mild power gains eventually... I picked up the car from an elderly gentleman near the border of NSW and VIC, its honestly a bit rough and looks like its been driven on a farm (because there was so much dirt underneath). Last week I dropped the subframe and emptied the old fuel out + added a new fuel pump (think the old one went bad from old fuel). Now I'm onto fixing a coolant leak at the rear of the engine + adding a new radiator as the old one is corroded. After that i have a new bumper, coils (as the old were leaking) and lots more
    • Welcome buddy! Plenty on here and YouTube. What are your plans for it? Good luck with the Rwc and Rego bud!
    • Love this so much! Please post a photo when you have a bike on the trailer.  I was a little bit worried about having a tow bar on the Skyline, but having it hidden behind the number plate is genius
