G'Day guys just trying to find a really cheap 32 to put my 25/30 in, i already have a bent r32 so i only really need a shell, just after something cheap, condition is not that important as long as its not rooted and fairly complete panel wise.
Located in launnie,
PM or SMS on 0408 117 171
Cheers Daniel.
https://www.sau.com.au/forums/topic/362258-wtb-cheap-r32-or-just-a-bodyshell/
Hey bud i saw that on gumtree and sent him a message and he told me its sold.
Thanks though,
Also i dont mind if i have to repair a shell, as long as its not too bad, i have a damaged shell i can cut parts out of if necessary.
  • 3 weeks later...
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
